1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | My 235 was running pretty smoothly. I cleaned the plugs, then re-installed. ( they each had a little black soot, nothing too bad ) Started her up, and then followed an old timers advice and proceeded to back all of the plug wires back off of the plugs slightly in order to " burn 'em off" a little while it is running. I got to the last wire and when it shocked the [censored] out of me, I dropped it and prceeded to knock off the adjacent wire as my hand beat a hasty retreat. Now both plug wires are hanging loose and sparking like mad all over the block, starter, etc. After trying to replace the two wires multiple times and getting shock repeatedly, I decided < duh > to cut her off and replace them. Now when I crank her up it sounds and feels like I am only running on 5, maybe 4 cylinders. Question: Did I burn up the wires, screw up the distributer, or what else could I have done to screw it up? Yeah, it was a really dumb mistake, and the hell of it is the engine was running rather nicely in the first place. ( if it anin't broke, don't fix it, huh?) At any rate, I appreciate all the help you folks with experience can give me. Thanks. | | | | | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | Sure you put them back on in the right place?
firing order: 153624 | | |
#6377 01/23/2002 10:08 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | one question: did you pull the wires off with your bare hands? it would be a good Idea to get a spark plug wire puller, cause you can really get hurt by that electricity. Some systems shoot electricity through those wires thats 30,000 volts and up. Once the wires are off of the plugs, the electricity has to go somewhere. good luck, and be careful. did you make sure you seated the wires all the way on the plugs? sometimes they wont fire if they arent seated all the way.  [ 01-23-2002: Message edited by: gmcfan ]
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#6378 01/23/2002 10:29 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I believe that his problem will be solved if he switches the two wires that came off.(pull off the plugs and switch)
