2 members (Maybellene, klhansen), 91 guests, and 2 robots.
Topics128,034
Posts1,055,544
Members48,425
#637129 04/12/2010 11:59 PM
Hi Bolters Ijust finished rebuilding my steering box and have not been able to find any information on the oil weight for the box what is everone using.
i used corn head grease from john deere. plenty of research on various lubricants with results some where here on the site.
For me, Cornhead grease from John Deere is the stuff that worked on my 37 when nothing else did. I tried everything else out there, and it is the one. Also not very expensive!
1 Offline
I just used John Deere corn head grease myself. I was going to use CV joint grease but the corn head grease will actually "flow" into the bearing cages and such in the box. I removed the lower side cover bolt for a vent and made a pipe plug fitting with a grease zerk in it to go in place of the fill plug. I filled the box until new grease ran out the lower hole where the bolt was removed. I reinstalled the bolt and put the factory fill plug back in place. It took me a full tube to fill it.
