| | | Forums66 Topics128,032 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | Hi Bolters Ijust finished rebuilding my steering box and have not been able to find any information on the oil weight for the box what is everone using. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i used corn head grease from john deere. plenty of research on various lubricants with results some where here on the site. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | For me, Cornhead grease from John Deere is the stuff that worked on my 37 when nothing else did. I tried everything else out there, and it is the one. Also not very expensive!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2010 Posts: 28 New Guy | | New Guy Joined: Feb 2010 Posts: 28 | I just used John Deere corn head grease myself. I was going to use CV joint grease but the corn head grease will actually "flow" into the bearing cages and such in the box. I removed the lower side cover bolt for a vent and made a pipe plug fitting with a grease zerk in it to go in place of the fill plug. I filled the box until new grease ran out the lower hole where the bolt was removed. I reinstalled the bolt and put the factory fill plug back in place. It took me a full tube to fill it. | | |
