| | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Hi,
I reconditioned an old electric wiper motor and it works and fits in well. I'm not sure what the best way to connect to the power. I have a 12 volt system - should it connect to the headlight switch power? The ignition switch power?
Any suggestions are welcome - Thanks
Doug | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | I would fuse it , then attach it to the ignition switch (on) terminal.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think the some of the stock ones had a switch on the motor ? There is a hole on the access plate in the header panel. I used a Painless wiring harness which included a switched power feed for the wiper motor, wired to a switch in the dash. | | |
