| | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hi All
I am cleaning the whole truck, removing rust etc, not sure if I can get all of the rust out, but can I clean with phosphoric acid, use eastwood rust convertor and rust encapsulator, then SPI primer, Eastwood chasis black.
Will this combination. Please advise and apprecaited so much
Ganesh | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | First degrease everything preferrably with a power washer and then use a power wire brush wherever you can to remove as much rust as you can. I would skip the phosphoric acid. It's just too messy,toxic and requires a lot of water to neutralize. Go right to the rust encapsulator and chassis black.You can skip the primer if you want.The chassis black goes on pretty thick unless you dilute it following Eastwoods instructions. You may get flash rust before coating if you try to do too much area at a time.
Drew
| | | | | Joined: Dec 2006 Posts: 26 New Guy | | New Guy Joined: Dec 2006 Posts: 26 | I would second that. I have found the rust encapsulater makes a fine base for the chasis black. I would give the encapsularer plenty of time to dry. | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks for that update, so verdict is stay away from phosphoric acid.
Thanks for the tip
Ganesh | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ... so verdict is stay away from phosphoric acid... Ganesh well, more like stay away from that combination, phosphoric acid is excellent for the right purpose, and not toxic, especially compared to the lacquer thinner, mineral spirits or acetone you'll use to thin the paint or clean it up  Bill | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | well, more like stay away from that combination, phosphoric acid is excellent for the right purpose, and not toxic, especially compared to the lacquer thinner, mineral spirits or acetone you'll use to thin the paint or clean it up  Bill Not only is phosphoric acid not toxic but it is in just about every soda made. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Well, I consider any chemical that has the potential in high concentration such as a Phosphoric Acid wash to be a health risk. Here is the MSDS which I trust to be more accurate. http://www.sciencelab.com/msds.php?msdsId=9927393Just my added 2 cents.
Drew
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Drew - most anything can be a "health risk" if used carelessly, always use proper care with any chemical - "toxic" has a specific meaning, many products are considered "irritants" and "hazardous" in concentration, but not "toxic" .... I much prefer things that don't produce hazardous fumes when used properly, and are easily neutralized with water like phospho
Bill | | |
