| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63634 07/29/2006 10:02 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Installed my flywheel, PP and disc today. This is an 11" PP and disc on my 261. Been about 30 years since I did one on my old VW. Here's what I did: a. Installed flywheel with lift help from my hydraulic jack. Went on fine. Torqued bolts to 65#. b. Checked my disc to see the side that was marked "flywheel side". Slipped the PP and disc onto the flywheel face and secured them with one bolt at the bottom. Inserted the alignment shaft and made sure it was straight and into the pilot bushing. c. Installed all PP bolts with lockwashers and then torqued them to 35#. Removed alignment tool and checked that the disc was centered in the diaphragm opening.
Sound right? Appreciate any feedback. I also assume that the disc is held tight between the face of the flywheel and PP face until the release bearing depresses the diaphragm teeth and "pushes" the disc away. Is this correct?
Tomorrow, the release bearing gets greased and installed. Then the tranny goes on! | | |
#63635 07/29/2006 11:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds right to me. Put a small amount of grease on the fork where it pivots on the ball. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63636 07/30/2006 12:37 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 49 geezer, just a little clarification, the pressure plate fingers when pressed release the pressure on the disc through a fulcrum and lever setup. That is why as your clutch wears your freeplay in the pedal disappears, hope that helps. | | |
#63637 07/31/2006 5:50 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I'm just about at the same point-I'm ready to reinstall my flywheel/pressure plate & then grind down my input shaft & bearing retainer on the T5. (By the way, thanks to this site for the play doh removal tip for the pilot bearing). Questions: 1) should I lubricate the input shaft splines? 2) Is there a place to lube the clutch pedal pivot? 3) Do auto parts stores carry the fork retainer clip for the ball stud?
Thanks in advance | | |
#63638 07/31/2006 9:43 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Check your manual's lubrication charts for any spot that requires oiling or grease. I read in my manual that you should lubricate the input shaft splines. So I did as well as coating the release bearing with some lube (just a small amount)inside in the recess and where the fork rides. I know that Carter sells the retainer clip. | | |
#63639 07/31/2006 10:07 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A small amount of grease on the trans splines.There are fittings on the pedal shafts 59 models on back. A small amount on the ball & fork. I douht if the part stores have the clip but the specialty stores do. I,ve got some extra laying around. E mail me & i,ll mail you one if you don,t find it locally. [email protected] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63640 08/01/2006 10:46 PM | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks for the info. I ordered the clip from Carter's. At $1.45 I told them they could close early today. | | |
