2 members (Guitplayer, MickeyP),
70
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63632 07/29/2006 6:47 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | this number is on the front spring hanger at the rear of it- drivers side ( C D 3732825 ) is this a chevrolst or gmc frame? Where should I look for frame numbers I think it is a late 50s frame 56 to 60? | | |
#63633 07/29/2006 8:20 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that looks like a part number, and is likely to just be "GM" as they use common parts - for the year ID, if a 55+ Chev frame, the main part of the vin will be stamped on the top of the drivers side rail in front or behind where the steering box mounts - the number will start with the 2 digit year designation, like 56L####### - not sure about GMC's location, but the number pattern would prolly be different
Bill | | |
