1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#63632 07/29/2006 6:47 PM
this number is on the front spring hanger at the rear of it- drivers side ( C D 3732825 ) is this a chevrolst or gmc frame? Where should I look for frame numbers I think it is a late 50s frame 56 to 60?
#63633 07/29/2006 8:20 PM
that looks like a part number, and is likely to just be "GM" as they use common parts - for the year ID, if a 55+ Chev frame, the main part of the vin will be stamped on the top of the drivers side rail in front or behind where the steering box mounts - the number will start with the 2 digit year designation, like 56L####### - not sure about GMC's location, but the number pattern would prolly be different
