0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#636075 04/08/2010 11:02 PM
I have, what I think, is excessive play from side to side in the steering of my '53 3100. The tie rods are tight and the play seems to be in the steering gear box. Can anything be tightened in the box?
3B Offline
Hy eightfan, yes the steering box can be adjusted for wear, someone here will know how to tell you how to find a copy of the maintenance manual on line, I'm not confusilator savy enough to do that.
which should I use for reference for my '53?
I'd say either one. They look the same to me.
I posted them both because a 1953 manual is not on-line and does not seem to be sold by reproduction parts vendors or on eBay.
Perfect.....thanks!
Either should do, just as Tim says. The procedure is pretty much the same all the way up to the current trucks. You may want to re-check the tie rods, though. If you're still using the priginal style adjustable tie rods, they could be "tight" when doing a static check, but have play in them under load when driving. There are instructions for setting the tie rod and drag link preload in the same section as the steering box.
Bill Burmeister
