5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#636037 04/08/2010 7:16 PM
On my 61 GMC with a Hydromatic (4spd auto) is there a nutral safety switch to make sure you can't start in gear? I don't have a schematic yet but I thought there might be one. The the truck has been sitting for at least 15 years and now that I,m ready to get it running it won't turn over. There dosen't seem to be a load on the electrical system, like the starter is under load. But before I start meassuring voltages and see whats going on I thought I would ask.
1961 GMC 3/4-ton with matching 10ft Fleet Aire camper (restoration work in progress)
1970 Volkwagen Squareback (restored for daughter's 1st car)
1958 Fleetliner 14ft runabout (restored)
2003 F250 4dr 4X4 V10
Pix on Flickr
if it's automatic doesn't it have to be in park or neutral? can you just jump 12volts to starter stud to see if it will turn over?
I have the sames trans and NO there is NO SAFETY Switch, YOu can start it in any of the gears including reverse, WHen in doubt, jack up the rear axle to clear the ground and try it.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I got the gas out and hooked up a gas can with a new batery and turned the key the ignition switch didn't dim and nothing happened. I ran out of time so I couldn't look at it any further. Thought I might get lucky and there woud be a position for the gear selector. Guess not. I was going to jump the starter next to see if the starter was good or not. then trace things back to the switch. With a 900lb camper on the backof the tuck right now al I want is to get it off the truck so it will be easier to work on it. I plan to spend two to three weeks working on the truck figuring out how much work it will be then see how bad the camper is and how much it will take. Big project, I guess I won't look for any lucky breaks and just resolve myself that it's going to be a challange, but that's what I like.
Pix on Flickr
