| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ok, quick blurb of where I am, the 52 1Ton has now been chopped down to a 1/2Ton and I have removed the rear axle.... I planned on using the stock 1 Ton springs even though I was swapping the axle out for a newer one....
On my way of taking the axle apart, I realized that the 1 ton Leaf springs are 2 parts. Can I remove the added set that sits on top of the main springs and just run the 8 springs together?
Will be a somewhat softer ride I would expect. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, you can remove the overload spring packs. No it won't be any softer when empty than it was before when empty. The overloads don't come into play till some load is already in the truck.
Grigg | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Hey Jackyl- I'm sending you a PM.-Whitman | | |
