10 members (Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 1 invisible),
58
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 35 Apprentice | | Apprentice Joined: Mar 2010 Posts: 35 | This is my first old truck and I have no idea what or where to get a oil filter. My local auto parts said they don't show a filter for my truck.
1962 Chevy C10, inline 6 (not sure what size), oil filter seems like it would be a canister type that goes in this container on the driver's side of the engine??
This may seem kind of stupid but I have never owned a truck of this age that does not have a screw on type / external filter.
Thanks in advance for your help! | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Do you have any way of showing us some pictures of your oil canister? Mine is a fram type that takes a C4P filter, the canister is attached to the exaust manifold. | | | | | Joined: Mar 2010 Posts: 35 Apprentice | | Apprentice Joined: Mar 2010 Posts: 35 | | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The canister right behind the A/C compressor is your filter housing, and it will contain a replaceable filter element. The two most popular ones were AC and Fram, both available as extra-cost options at the time of the truck's purchase. Yours looks like an AC, as Fram filter housings were normally painted orange. When you remove the lid, be prepared for a little spillage, so have a big wad of rags or a small pan underneath the filter housing. Once the element is removed, there will be a residue of oil in the housing that will need to be removed with a suction gun or soaked up with throwaway rags or paper towels. I don't have filter element part numbers handy, but I'm sure someone will chime in with them soon. The filter element is sandwiched in between a flange on the center tube, and a spring-loaded washer attached to the housing cover, so pressurized oil from the line attached to the side of the filter canister is forced through the element, and drains back into the oil pan through the tube attached to the bottom of the canister. it's called a "bypass" filter because oil does not go from the filter to the engine bearings. A small orfice in the outlet fitting controls the flow, and a slow, steady flow of oil gets filtered and drains back into the oil pan. If you can't find a number on the filter element you remove, take some measurements and check the parts store's stock for one that interchanges. As long as the element seals at the top and bottom, it doesn't necessarily have to completely fill the canister side to side. Jerry
Edit: Don't forget to change the rubber ring gasket under the cover! Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | See if they can cross reference WIX #51100 | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | A Fram C4P will also fit since it sure looks like an AC as Jerry said.
Ed
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Look in the Tech Tips, they have some good info on the AC filter and housing. | | |
