| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I thought I'd post and maybe save someone some time if they make a similar mistake.
I got gas for my welder some time back, but I was still using the flux core wire -- no problem so far. In fact the combo of flux core wire and gas allowed me to weld in some places where I thought it was going to be too windy.
I finally ran out of the flux core wire and put on a spool of .030 solid wire.
Hard to get a smooth arc, no penetration. Beads looked like steel caterpillars sitting on top of the metal.
I was perplexed for a couple of days, then I had a Doh! moment. I had forgotten to change the welder to positive ground when I changed to solid wire. All better now.
Here's hoping this saves someone else some aggravation.
regards, Leon | | |
