5 members (Otto Skorzeny, Bill Hanlon, 48jim1ton, dt235sd, 1 invisible), 98 guests, and 2 robots.
Topics128,035
Posts1,055,556
It has been so long since I took it apart that I forgot how this part (and a few others)goes. It is a bakelite tube just over an inch long and has a flange at one end. I think it goes into a hole in the hub of the steering wheel, but I don't know if the flange goes on the side of the hub with the metal screwed to it or the side of the hub with the larger diameter end of the hole. Any pictures of this stuff would be greatly appreciated. Thanks - Scott
55 1st Chev.
Leo Offline
Moderator
Moderator
I was just working with that part this afternoon. Yes, it goes into the hole in the steering wheel hub. The flange goes up, it actually fits into a countersink that is in the hub. Just make sure the wire and spring come up into the same hole from the bottom.
Thanks a lot. Yes, I remember the wire and spring. Maybe it will be obvious which end is up on that. Good luck with yours and thanks again!
Scott
55 1st Chev.
