2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | just got my truck back from the body shop 54 3100 painted juniper green. I have stock style steel wheels. They will get painted green also. Should the back of the wheels get the same green or maybe black semi-gloss? also what color would you recommend for the steering column? the interior is cream with a new black steering wheel.I know it's personal preference just looking for ideas . thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you want it painted as original? If yes, the steering column was black.
If you want the wheels painted as original, they were black on both sides. However, you would not easily notice the color of the back of a wheel.
| | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | thanks Tim, No not going original just looking for ideas, thanks. Now it's back to work on my hard to start motor. Still haven't figured it out. Happy Easter. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Tim, while we're on the subject of colors, I thought the Burb’s interior was different than the pickups. I’ve made a comparison of a 1949, 3116 suburban column and a 1950, 3600 pickup. Taking into consideration the date and plant of manufacture they both appear to be quite similar in color. http://www.pbase.com/dennygraham/image/123248501/large When exactly did the Burb take on its own color scheme? I often get the argument about the black steering, that started with the ’54’s didn’t it???? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Tim I've got that service bulletin but I never would have found it. DG
