| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63439 07/25/2006 5:03 AM | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | Can anyone tell me what years transmission will fit in my 1966 chevy truck it has a 250 engine and from what I found out about my trans the first gear is 12:09 this trans is geared to low just had rear rebuilt it did have 4.11 gears and I had it changed to 3.42 gears but truck still wines at a higher speed | | |
#63440 07/25/2006 5:20 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | All three speeds will have 1:1 ratios in high gear, so putting a different three speed or even four speed in won't change the engine revs per speed. An overdrive or a five speed with overdrive fifth gear would be options.
You may be going about 20% faster than indicated if you didn't change the speedometer gears in your transmission. | | |
#63441 07/26/2006 9:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The T-5 from a s-10 pickup is the popular swap lately. I just put one in my 55 & love it. The 5 th gear is o-drive & you can,t even hear the engine running. There is lot,s of info in tech. section & in these posts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
