| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Question on ports on master cylinder: Does it matter which line goes to which port? Front port for front brakes, rear port for rear brakes? Or does it not make any difference?
(Working on 1953 3/4 T. Chev. PU drum brakes--)
Thanks--T.K. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | TK - no it doesn't matter, other than convienience of line routing: "when increasing the pressure at any point in a confined fluid, there is an equal increase at every other point in the container, i.e., any change in pressure applied at any point of the fluid is transmitted undiminished throughout the fluids.
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Depends on what master cylinder you're using. If you have the Corvette style master cylinder, then np, it won't make a difference as that one was designed for 4 wheel disks with the same caliper on all 4 corners. But most disk/drum and even later 4 wheel disk masters will have specific front/rear porting. It's pretty much universal on modern vehicles (I have never seen any exeptions to this) for the port nearest the pushrod end of the MC to be for the front brakes, the other port for the rear.
Bill Burmeister | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There are three issues that I think of that make a difference.
First is the size of the bore. If both bores are the same size its a non-issue but if they happen to be different sizes you need to match them correctly to front and rear.
Second is reservoir size. Disk brakes require more fluid displacement and therefore usually require a larger reservoir. In a front disk/rear drum application that would make a difference.
Third is the possible presence of internal residual pressure valves. When needed disk brakes need a 2 pound valve and drum brakes need a 10 pound. If your master has built in residual valves they need to match your brakes.
While you describe your project as drum brakes if you are using a newer master it was probably designed for a disk/disk or disk/drum system and some of these issues could impact your project.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
