5 members (Phak1, tclederman, Charles in CA, wvstovebolt, 1 invisible), 210 guests, and 4 robots.
Topics128,083
Posts1,055,967
Members48,430
#633905 04/01/2010 12:53 AM
Help.... I was watching a car show on TV and they showed a guy who did some pretty nice work making a custom dash using a piece of stainless steel and a drill press I believe, with some kind of device to put swirls in the finish that looked cool. I would like to try this for a custom look for my truck and have just searched for it on google, but cannot find any reference to this show, or technique... Has anybody seen this type of work and no what it is called? Thanks
If I remember correctly the swirling you are talking about is called "engine Turn".
Tried it, pretty tough. Maybe I was too picky though.
Edit: I think aluminum could be a better choice for a few reasons. More malleable and easier to engine turn. I have seen it done on steel with a drill and mandrel (think that's what it's called) and on aluminum with sand paper or even steel wool by hand.
Lowbow is right...process is called " Engine Turning ". You see it on a few European cars as well as customs. I would think once you get the hang of it and take your time, would work out OK
1940 Chevy KC 1/2-Ton
Prof, I'm not sure about the show,but here's the kit
It's available in the UK through Frost,but I'm sure someone like Eastwood may do a similar kit.
More pix on Flickr.
Search for some sheet stock that already has the engine turn effect applied. I have seen it sold, just can't remember where. Then all you would have to do would be to cut, brake, and drill to fit.
I think doing it yourself without a mill or some way to keep it precise will be next to impossible.
Originally Posted by aggie jon
SI think doing it yourself without a mill or some way to keep it precise will be next to impossible.
Exactly. If you don't have some way to precisely position each turn you're going to wind up with an embarrassing mess.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Kit is available in 1/2" item #13118 and 1" item #13117 for $34.99 from Eastwood. Complete with instructions; designed to be used with a drill press.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
Moderated by  ndkid275, Phak1
