| | | Forums66 Topics128,179 Posts1,057,130 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 7 New Guy | | New Guy Joined: Jan 2001 Posts: 7 | Hi, I feel bad asking this here considering the year of what I am working on. I am working on a 1984 GMC 7000 . I am replacing the blown DD with a 3208 Cat. This truck has the steel hood. Does anyone know if a tilt front from the same era Top Kick will work, if I use the fender extensions and rad suport from the Top Kick. It appears the cabs are the same. Or does the cab sit forward more there making a differnence in the length of the hood? Any help is appreciated. Thank you, Jim | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If, i'm not mistaken, the cab does sit more forward, & also higher,on a Top Kick, than a regular conventional. | | |
