8 members (DougH6100, Gdads51, Donf, Hanks custodian, FAST55, Gray_Ghost, Bill Hanlon, cmayna), 142 guests, and 1 robot.
Topics128,162
Posts1,056,950
Members48,458
#633398 03/30/2010 5:29 AM
Both the rear springs are broken on my 1961 chevy c10. Does anyone know where I can find new stock hight rear springs? Thanks
k10 Offline
coil or leaf?
Srry, i should have been more specific. they are coil springs.
lmc has coils for sure, check them out they carry alot
Most of the classic truck part suppliers, along with the chassis suppliers sell stock height replacement coil springs. Before buying any of them, be sure to ask the wire diameter of their "stock" springs and compare this to your originals. Most are much heavier than stock and won't bounce at all unless the bed is fully loaded. Interestingly, most of the lowering springs are much smaller diameter than stock and greatly reduce the load capacity. You might be happier installing a set of used originals if you just want to keep it stock.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
