5 members (Niels V, Phak1, MNSmith, 2 invisible), 77 guests, and 4 robots.
Topics128,180
Posts1,057,141
Members48,463
I have a '48 chevy and I installed a 10 bolt rearend with new leaf springs and u-bolts along with a bottom shock convertion kit and top mount for the frame bought from CCP.
Does any body have any pics of your conversion and how you mounted the shocks to the top of the frame.
What kind of bracket did you use?
Thanx for your help!
mike
You can use the top mounts from a 50's truck like mine it's a 52 you'll have to drill 4 holes 3/8s and mount them at 45 degrees from the bottom mount post toward the front of the truck just to be sure I'll check the degree again and post it
Pete
Mike I sent you a PM on this subject and an email to boot. If you need any pictures or measurements for mounting the upper backet just let me know. I've got a '50 that I'm SLOWLY restoring, right Pete?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
