Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#632437 03/26/2010 10:47 PM
I have a 64 C20 with a 292.
Just purchased, making repairs to pass safety in Missouri. I just cahnged the battery cables to 1/0 and now upon start-up and shut down I am getting a squeaking nosie. Everything was o.k. up till now.
I do not think that less resistant with cause that noise?
Any help?
Born Lucky #632441 03/26/2010 11:16 PM
Riding in the Passing Lane
I don't either. We need a better description of the noise to get an idea.
1972 Chevy c10 Cheyenne Super
The noise is almost like my belt is loose.
I will check that tomorrow.
Can a loose belt squeak on start up and shut down?
Born Lucky #632525 03/27/2010 3:44 AM
Definitly. The belt on these 6 cyls. engines don't have a lot of contact distance on the alt. They need to be pretty tight. The alt pulls a big load when you first start up to recharge the bat curent that was used by the starter.
pull the belt off and check the bearings on the alternator/generator and the waterpump. spin them by hand. just to eliminate those possibilities.
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
ctrworker #632625 03/27/2010 3:23 PM
This is what I was thinking. want to remove the belt and check both water pump and alternator then reinstall belt.
Thank you for the help.
