12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
103
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | I'm looking at the Tim Tygart's obsolete Chevy catalog looking at the Brake Shoe Spring & Pin kit. Part # BHK001 (I would post a link to the web-site but it doesn't show a picture so it wont help much) anyway it includes all the springs adjusting screws and the "J" hook with coil springs. It has the years listed for 1951-1958 and the next set is for 1960-1963. What the heck happened to the 1959 brakes that there so different than the 58's... Could I possible use the set for 1958 1/2 tons to use on my 1959 1/2 ton, and if not were can I find a set of springs and adjusting screws? I've looked at LMC,classic Chevy,brothers and so on and can not find anything. Please help. Thanks for your time. Oh and if I posted this in the wrong area , I'm sorry......JOSH
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only thing I know of that's different between '58 and '59 on 1/2 ton brakes is the drums on the '59s with Positraction, which uses a Spicer 45 GMC spec axle instead of the Chevrolet axle.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | Well I know I dont have Posi so should I be ok with ordering the brake springs and adjusting screw set for a 58? Wonder why they have it listed for the 58 and not the 59. Typo maybe? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I had an eaton HO33 in my 59 jimmy... not from the factory, but from a PO. Anyway I got a 60s something 12bolt to replace it, and most if not all the brake parts would swap over, including the drums, cylinders and shoes. I ended up not using the 12 bolt. I am now placing a full floating 9 inch rear in my truck. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The 59's use the same hardware and the same drums as the earlier trucks but use a wider shoe on the rear. It happens to be the same as used on the front. The narrower shoe used on a 55-57 rear will work as well. Fred
