| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63185 07/19/2006 1:20 AM | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Since I don't have a good place to work on my truck now I'm getting someone else to change the throw out bearing and clutch. He wants me to get the clutch first so he can do the work and get the truck out of his shop quickly. It's a 46, 1/2 ton w/ 4 spd. I read where it should have the larger of the 2 clutch sizes since it has the 4spd. I can't find the larger clutch. Will the smaller dia clutch work as well for a retired '46?
Union, Justice and Confidence
#63186 07/19/2006 5:18 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If it has the HD clutch it will be an 11".
Flywheels are drilled for only one size pressure plate. In some cases you can use a smaller disc without changing the pressure plate size. If you want to use a smaller pressure plate and disc you will need to change the flywheel.
The standard clutch size is 9-1/8"
See the USA in your vintage Chevrolet! My Blog | | |
#63187 07/19/2006 5:08 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Swampcat,
I'd be a bit surprised if you really had the larger clutch.
The 2 I've torn into have each been the smaller 9" clutch and pressure plate. They were both standard 1/2 ton's with 4-speed tranny's.
I also went through this same line of questioning but it always seemed that the larger of the discs were generally used in the larger trucks. | | |
#63188 07/19/2006 11:38 PM | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Jed & Dave, y'all are probably right. That's probably the reason why I haven't been able to find the larger clutch. Thank you for your replies, Jacques
