| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | It kind of seems like a dumb question but where do those foam spacers go behind the door panel. I got the spacers from Jim Carter.
I can't say not knowing.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What would be the part number?
1954 truck?
There are round "spacers" that go around the widow-opener post and the door-opener post; and small rectangular "spacers" that go behind the door-latch control rod.
| | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | The part # is UP123.
Its a 1954 Chevy 3100 Truck
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd have to see the 12 parts. How many of the small rectangular pieces do you have. I'll check the Factory Assembly Manual but I think the go on the door, behind the door-latch control know (to keep it from rattling). The round ones, go on the posts to the door handle and the window-winder handle. Put the round pieces on the posts before putting on the cardboard panel. How many of each round piece were in the kit? | | | | | Joined: Dec 2009 Posts: 10 New Guy | | New Guy Joined: Dec 2009 Posts: 10 | There are 4 foam rectangles and 4 round foam disks and 5 cardboard disks the same size as the foam disks.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | This is from memory only and an old memory at that but I believe that the foam rounds are for behind the door panel at the door latch and window crank with the thin cardboard versions being for in front of the door panel underneath both latch and window crank to serve as washers, and the final 4 rectangles, I believe go behind the door latch cross bar to keep it from rattling against the door metal. | | |
