0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#63137 07/18/2006 12:41 AM
2 Offline
On my 250 Inline 6, I have the 1bbl Rochester carburetor (not the monojet).
To tell you the truth, I don't know EXACTLY what model it is, but it has the two-bolt pattern for the base. Just two studs keepign it on.
I found this adapter and was wondering if it would fit my application. Because it looks like (by that gasket there next to it) that it uses 4 studs t obolt on to the intake.
It also says at the side, DOES NOT FIT ROCHESTER CARB. Do you think they mean the 2bbl carb I'll be putting on or the spot on the intake?
Dan
1967 Chevy truck "The Hurricane"
WARNING:
This suspect has a tendency to jerry-rig.
"My engine ain't fast, but I pulled a tree trunk out of the ground once."
#63138 07/18/2006 2:02 AM
Junior Member
Junior Member
I used that adapter to replace my 1bbl rochester carb. It worked beautifully! I also used the holley weber 2bbl from the same site. The linkage kit didn't quite fit properly but with a few modifications it runs perfectly.
Regards,
Evan
#63139 07/18/2006 2:14 AM
2 Offline
So it does work! Thanks a lot for the reply Evan, I can't tell you how happy I am knowing I'll have that crappy old 1 barrel out of here in a snap.
With much appreciation,
Dan
WARNING:
