2 members (Dennys28, 1 invisible),
96
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | 1962 1/2 ton - Well, I read up on it, sounded easy enough... just remove the bolt and smack it a few times and POP out it comes! I don't Think so, I spent a good hour hamming away with a 2lb. hammer and NO LUCK! The uppers popped loose pretty easy. I'm trying not to use a Pickle Fork because the ball joints are fine and I don't want to spend $189 ea. to replace them (by tearing up the boots) - just trying to put on my new spindles. DOES ANYBODY HAVE A GOOD METHOD OF GETTING THE LOWER BALL JOINT TO BREAK LOOSE? I have no torch , so I can't really put heat to it.
Thanks | | | | | Joined: May 2009 Posts: 45 Apprentice | | Apprentice Joined: May 2009 Posts: 45 | when you think you hit it hard enough, hit it harder | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This tool will do the trick. There is a lower cost version available from Harbor Freight that seems to be as good of quality. I have one of each, the HF one has held up very well. i could not find it in their online catalog, though.
Bill Burmeister | | | | | Joined: Oct 2009 Posts: 15 New Guy | | New Guy Joined: Oct 2009 Posts: 15 | Take a butane torch and heat it up alittle around the bung on the control arm and smack it with the hammer. Or...go to a good alignment shop that has some good guys working at it. You might hit it lucky and they might pop it out for free.
How do I know so much about these trucks? I stayed at a Holiday Inn Express last night.
| | | | | Joined: Jan 2010 Posts: 43 Apprentice | | Apprentice Joined: Jan 2010 Posts: 43 | Well, finally broke down and used the Pickle Fork (lubed it good with grease to keep it from ripping boot) and it popped after about 10 good smacks... HAPPY CAMPER :-) I think using grease and not being to aggressive with pickle fork worked very well in saving the boot from damage - should have tried this earlier, could have saved myself days of sore shoulders! | | |
