1 members (sron48), 104 guests, and 2 robots.
Topics128,154
Posts1,056,856
Members48,456
I'm converting my 6 volt '51 to 12 volt. I have a 1960 235 and I will be trying to installing a one wire alternator. Looking in Classic Industries catalogue for ideas I noticed that amperage varies from model to model. Fo a 1960 inline 6 it needs a 30 amp alternator. Any concerns if I get one that is more that 30?
You need enough alternator to power all the accessories you will be running with it. Figure out how many amps your accessories will be using and get a bigger alternator.
A side note: One wire alternators are fine for tractors and stuff with no accessories but if you plan to use lots of amperage you need an alternator that will sense usage within the system. A lot of people will tell you one wire alternators are fine but not many people that understand electric systems will.
Get at least a 65 amp alternator. 100 is better. The alternator will not supply any more current than the battery needs, so ignore those low-amperage suggestions. Even a 12 volt generator had a capacity of 35 to 50 amps, depending on the model and application. I can't imagine any reason you would need an alternator with less capacity than the generator it's replacing!
Like Cletis said, but don't forget to add in the lights too.
Larry
I don't own a vehicle that isn't old enough to drink.
Riding in the Passing Lane
I would use a 55-65 amp. 3 wire alt unless you are running an electric fan or some other high powered accesory. There is not a lot of belt contact on that 6 cyl. engine. A higher out put will slip the belt under heavy loads.
1972 Chevy c10 Cheyenne Super
When you're upgrading from 6 to 12 volts, it's worth remembering that your new 12v alternator delivers twice as much power per amp charge as your 6v generator did. A 65A 12V alternator delivers 780 watts, you'd need a 130 amp 6V generator to deliver the same power.
Alternators and generators are always quoted in terms of amps output, but it's the wattage that powers the electrical systems on your truck. The wattage demand won't change much unless you fit some power hungry accesories while you're going from 6 to 12 volts.
Stuart.
I used a 63amp alternator on my pickup and suburban.
1951 3100 Chevrolet
