1 members (baldeagle), 87 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#630156 03/19/2010 3:11 AM
OK I know this is probably on here but I have looked trhough hundreds of post and cannot find it
How much paint should I buy to paint my 53 3600 long bed? I will be painting the exterior only including inside the bed and the firewall, but not inside the cab.
I am using an epoxy sealer and single stage urethane (solid color...no metalics)
Anyone have an idea?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
I mixed 2 gallons of Dupont acrylic lacquer for My truck...
It was definitely more than I needed, but what if I needed paint
for a mishap later...Its also important that You box all Your paint together in one container...That way if You ever need paint
later You won't have problems with a mismatch...
I also used clear, but clear has no strength when sprayed
alone, so I added a quart of color to the clear which gives it the strength it needs to cross-link...
I know You are talking a single stage urethane, so I would
recommend purchasing 2 gallons knowing it will be more than needed, but You can bank the rest for down the road.. Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
Bill_B #630375 03/20/2010 12:58 AM
Thanks Bill
I think that is wise advice.
Rich
1953 3/4-Ton Chevy
More pix
RB53
