| | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | OK I know this is probably on here but I have looked trhough hundreds of post and cannot find it
How much paint should I buy to paint my 53 3600 long bed? I will be painting the exterior only including inside the bed and the firewall, but not inside the cab.
I am using an epoxy sealer and single stage urethane (solid color...no metalics)
Anyone have an idea?
Thanks Rich | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | I mixed 2 gallons of Dupont acrylic lacquer for My truck... It was definitely more than I needed, but what if I needed paint for a mishap later...Its also important that You box all Your paint together in one container...That way if You ever need paint later You won't have problems with a mismatch... I also used clear, but clear has no strength when sprayed alone, so I added a quart of color to the clear which gives it the strength it needs to cross-link... I know You are talking a single stage urethane, so I would recommend purchasing 2 gallons knowing it will be more than needed, but You can bank the rest for down the road.. Bill B | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Thanks Bill I think that is wise advice. Rich
