1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | I apologize for posting another timing related post because there are already so many, but after searching I did not find a solution that I understood.
When I attempt to time my '54 1/2 ton, I reach the limits of adjustment (retarding) of the distributor before I get to the timing ball. My flywheel is marked with a triangle, and then with the letters IUC, the embedded ball, and then the number 2. When I tried to time the engine, I initially saw the triangle, and then turned the distributor CW until the IUC entered the viewing window on the housing. At that point the distributor had reached the limits of its adjustment and I could not retard it any more.
I do not have a lot of experience working on cars, so this could be a very simple issue. I have read, printed out and followed a bunch of advice from these forums already – thanks everyone!
Is there a chance that the distributor is off by a tooth? Is there another way to change the relative position of the distributor to the adjustment plate?
Here is a synopsis of what I have done so far to troubleshoot this: The vacuum advance is disconnected and taped over.
I have adjusted the points (.016) and recently bought a dwell meter. The dwell is at 30. The RPMs are at about 800.
I cranked the engine and confirmed that the rotor is pointed toward the correct wire at roughly TDC and that all the wires are connected in the correct order.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes there is another way to adjust the dist. There is a clamp with a slotted screw just underneath it. Set the plate in the center & tighten it down. Loosen the screw & set the timing by turning the dist. Tighten the screw. Then you can use the octane selector to tweek it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Sounds like you're off a tooth. Just pull the dizzy out, and when the rotor is free, turn it slightly CCW and reinsert it. That should get you the adjustment you need.
If your dizzy has the octane selector on it you might be able to get enough out of that to bring your timing back a little. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | At 800 RPM, you're starting to get centrifugal advance, which will make it appear you're over-advanced. Drop the idle speed to 500 or less, and use the screw clamp around the distributor housing to set the initial timing with the hold-down bolt centered in the slot. Then tweak the setting up or down a little if necessary for fine-tuning. Jerry
| | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | Thanks everyone. I found the screw clamp under a nice layer of black grime and adjusted the position of the A/R scale. I also adjusted the throttle screw down to about 500 RPM.
I used the 12V battery from my car and in about 1 minute I had the ignition timed.
I reconnected the vacuum advance, made a couple more adjustments, and then took the truck out for its maiden voyage from its new home.
I drove around the block and it ran like a champ. Now I've got a permanent grin on my face and a running 1954 1/2 ton pick-up.
Thanks again. This site rocks!
