| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 38 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 38 | G'day Everyone on Stovebolt,
Just wondering if anyone has had experience swapping a six cylinder in a C30 to a V8. The truck currently has a 4 speed manual. What bits and pieces would need to make an effective and safe swap. I would like to use the truck to be able to tow my 1940 Chevrolet truck on a trailer to interstate meetings. I am just at the idea stage of things deciding which way to go. Any help would be appreciated.
Kind Regards Glynn | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 350 and 454 were factory options in '75 so all the parts are available to make this swap. The exact list of bits and pieces is going to vary depending on exactly what options you want to hang off the motor or in the engine compartment.
I believe the engine mounts on the frame will be different because thde 292 is unique. Those mounts and the correct exhaust manifolds are the first things I think of.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | A couple of other items to add near the top of your planning list would be an appropriate rearend ratio that would complement the overdrive transmission choice .ie a good towing package for the interstate travel.
Good luck | | | | | Joined: Mar 2009 Posts: 38 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 38 | Hello,
Thank you Steve and Wrench for the replies. Good to know that the V8 was an optional extra - it helps to know that something should fit before I start to play. Now just need money and the time to be right. Getting the two of them together always seems the tricky part!
