| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | hello i wanted to put new shocks in my 59 truck . but now i saw the bolts wehre the shocks get mounted (screwd) on are all broken . how do you call this pins . so i can order them thanks gregor | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I don't think anyone stocks them, and some positions they're tack welded into the bracket, but you can use grade 8 bolts to make do - also some new shocks come with hardware for at least one end
Bill | | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Torch the old stud off.Replace with new bolts & nuts.the torch works wonders with this problem.Should be able too knock out old studs with heat & punch
dan-pa
