5 members (NJC, 32Fordpuchoptop, 48jim1ton, BillyDon, Jman), 94 guests, and 3 robots.
Topics128,042
Posts1,055,601
#627746 03/10/2010 10:35 PM
hello
i wanted to put new shocks in my 59 truck .
but now i saw the bolts wehre the shocks get mounted (screwd) on are all broken . how do you call this pins . so i can order them
thanks
gregor
I don't think anyone stocks them, and some positions they're tack welded into the bracket, but you can use grade 8 bolts to make do - also some new shocks come with hardware for at least one end
thanks for the info
Torch the old stud off.Replace with new bolts & nuts.the torch works wonders with this problem.Should be able too knock out old studs with heat & punch
dan-pa
