4 members (Hotrod Lincoln, TexasJim50, MickeyP, rfs56trk), 76 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#627123 03/08/2010 10:29 PM
What side of a 52 Chevy 3100 1/2 ton was the antenna on out of the factory. Thanks
kipp #627126 03/08/2010 10:39 PM
Driver's side.
It was an accessory (installed by dealer or owner) and not a Regular Production Option.
http://chevy.oldcarmanualproject.com/radios/51rs/51rs39.htm
As far I know my 51 was put on the right side.it still played with the hood when is open.So I put it where the gas tank filler was Frenched antenna.power and gas tank in rear.unless you want to try the wire around the front winshield.no holes
dan-pa
