2 members (Gdads51, 3B),
116
Mod | | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Does anybody know if the interior cardboard panel(rear)trim is available for AD burbs? Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Tim,I just talked to mike and they are not available for the suburbans,just for trucks(the metal trim piece).Brian,you might call them and make sure . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | I looked at Jim Carters before posting and didn't see the trim ,just for the door panels. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You are talking about the metal trim that surrounds the cardboard panel,right ? I was told they do not supply them. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 23 'Bolter | | 'Bolter Joined: May 2005 Posts: 23 | Last I knew, they were not reproduced. | | | | | Joined: Jun 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 118 | Tim ,you are correct. Thanks everybody, guess I'll have to post in the want section in a bit. Just wanted to make sure. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sorry, I did not know that you were referring to the cardboard panels' metal frames.
