8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | 49 Chevy panel truck model 3100 with a rebuilt 216 engine. Attempting to set the engine up, but it seems to be running to rich. There is little or not smoke but the exhaust is so rich that you can't stay in the garage with the door open, my eyes burn and the exhaust makes it hard to breath. How do I lean it out so that it's not so rich and to get the engine to idle smooth. Thanks for the help.
Regards,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is something wrong with your carb. If it is a model B Rochester they are easy to work on. First make sure the mounting gasket has a cutout to alow vacuum from the manifold to reach the hole in the bottom of the carb. If gas is running down the throut of the carb when you shut it off, then you have dirt in the needle & seat or the float is bad. There has been a lot of posts on this subject. You might find a lot of info doing a search. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Thanks for the insight, the carb is a W1, that is typical for the 49 216 engine. The carb was rebuilt but I am of the opinion that there is soemthing wrong with it still. How does one lean it out to make it burn less rich. Thanks
Regards,
Dave
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can turn the idle mixture screw in but I dought if it will do much good. You are going to have to go into the carb & find out what is wrong. It could be a float full of gas or the level is not set right. The metering rod or link may not be going down into the jet. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | As to the idle mixture, your right I adjustred it and it did little or nothing. Will changing the octane setting on the vacum advance affect it. Thanks
Regards,
Dave
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Seems to me that running rich is running rich, not timing. I guess maybe poor timing wouldn't combust the gas/air charge properly, but that doesn't seem likely . . .
When we were reassembling our freshly-rebuilt 216, we also freshly rebuilt our Carter W-1. Along with some other kinks, we had a rich situation, with quickly fouling plugs, and dribbling gas after shut-off.
Turns out the float valve seat had worked loose (we probably hadn't tightened it properly), so gas would keep flowing, even with the float up. Easy fix.
Possible leaking float, as well. I know disassembling the carb can be a pain in the A$$, but take it slow, don't lose any parts, and check the float. It's not too bad to just pull the top off to get to the float. Float should basically sit level when the assembly is held level. There's a proper measurement, can't remember it right now. Double check the float valve and pin, and seat. If they're all good, and float is reasonably close, you should not get a drastically rich condition.
Report back what you find. Hope this helps!
-Michael | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Advanced timing will increase tailpipe hydrocarbons (unburned fuel) significantly, especially on a cold engine. Timing set around TDC will usually produce the fewest hydrocarbons, but the engine will run sluggish and possibly hot. In the earlier days of emissions testing, retarding the timing was an easy trick to clean up a car failing for high hydrocarbons. Retarding the timing could reduce the tailpipe hydrocarbons by 1/2 to 2/3rds. Manufacturers have been retarding timing on cold starts for years to clean up the tailpipe.
John | | |
