4 members (Wally / Montana, Lightholder's Dad, 2-Ton, 1 invisible), 109 guests, and 1 robot.
Topics128,051
Posts1,055,730
#626545 03/06/2010 11:43 PM
Does anyone know where to go to get original or original look 6 volt marker light for the bed on a 52 ton and a half. Approximately 2 1/2 to 3 inch diameter. I don't want to go with the new 4" diameter that are flat, but if I have to, oh well. Any helpful info greatly appreciated.
Glory Bound...
check around here, doesn't have to be listed as "6V", you can always change the bulb .... or you might find something here
Thanks a lot, looks like I'm having luck on the second website you recommended. Thanks again.
Raul
Glory Bound...
There were many styles of marker lites under the beds, many had a2 inch hole or so that a lite was mounted behind, those were a beehive stlye lens anout 2 inch long that poartly protuded thru the bed but were mounted on a thin canvas strip so there were flexable, then there are the armord type you see in the link that were mounted on the bed rail, but when you had cattle racks and pulled in too close to the loading shute you ripped them off, so many people put a piece of angle iron under the bed to screw these to and then they had some protection
