| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Does anyone know where to go to get original or original look 6 volt marker light for the bed on a 52 ton and a half. Approximately 2 1/2 to 3 inch diameter. I don't want to go with the new 4" diameter that are flat, but if I have to, oh well. Any helpful info greatly appreciated.
Glory Bound...
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | check around here, doesn't have to be listed as "6V", you can always change the bulb .... or you might find something hereBill | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Thanks a lot, looks like I'm having luck on the second website you recommended. Thanks again.
Raul
Glory Bound...
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | There were many styles of marker lites under the beds, many had a2 inch hole or so that a lite was mounted behind, those were a beehive stlye lens anout 2 inch long that poartly protuded thru the bed but were mounted on a thin canvas strip so there were flexable, then there are the armord type you see in the link that were mounted on the bed rail, but when you had cattle racks and pulled in too close to the loading shute you ripped them off, so many people put a piece of angle iron under the bed to screw these to and then they had some protection | | |
