| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Does anyone have a picture of the insides of a deluxe heater with the control valve mounted, or know where I could look for a picture, I did a search. Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | I've got a 55 2 series 3100, I think the Harrison deluxe heater is out of a 56, 3100 | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Thanks Avette4me , mine looks just like that, can you tell me if the heater control valve is hooked to the core with a hose 90 degree elbow. I bought this heater and it had no valve, so I got one just doesn't seem to line up just right. And then not knowing how it looked new , well you know !!!! Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes Ted, there's a right angle piece there, I've seen it available at vendors - this shows the position, other pics in the sig link below Bill | | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | Thanks, Bill I appreciate the pictures and your time,thats what I needed to see.....Thanks | | |
