11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith), 78 guests, and 2 robots.
Topics128,032
Posts1,055,523
Members48,425
#625022 03/02/2010 2:25 AM
I am looking into mounting radial tires on my 1970 GMC 3/4 ton. Would this work ok?
I have 7.50-16LT tires, would 235-85-R16 tires work?
What non-split rim rims work on these trucks? Would it be better to just update the rims and tires together? What year and make would fit the 8 bolt pattern?
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
The 235/85/16s will work fine, but you will need to go to a 1 peice wheel. Any 8 lug 16" up to '87 will work, you can also use up to '98 from 2wd 3/4 and 1 tons.
Bill Burmeister
Thank you. I think I will like the look of the newer rims also. My truck is a two wheel drive> I forgot to mention that. There are no modifications needed for these rim options?
Shouldn't be, the IFS used on the '63-'87s are pretty much the same, and they used the same wheel/bolt pattern for many years.
Bill Burmeister
Why wont radials work with split rims? Is it the bead style?
H Online: Content
Split rims have to run tubes- - - -they're not air tight because of the multi-piece design. I've run radials with the correct tubes in them on split rim wheels, but the radial-type tube is a must. Bias-ply tubes will chafe and wear through in a very short time. Some tubeless 16" rims will not fit over the big brake drums on early-model 3/4 or 1-ton axles because the drop-center rims are too small to clear the drums. A 17.5" tapered-bead tubeless tire will have the same height as a 16" tube type, but those tires and wheels are scarce and expensive.
What is the average price for mounting split rims?
What can I expect to pay for tires?
I'm in the process of looking for new tires for my 1946 dually (7.00-18 on split rims) and to order new the cost will be:
$169.99/each
$80 freight
$15/mount
$1287 total
I'm going to try and buy them here and there to see if I can get that price in half.
1946 Chevrolet 3800 1-Ton
More pix on Picasa
I understand computers and I like them, just not in cars.
