7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I'm not sure you are completely done with the top cover. When the 1/2 shifter shaft glides as smoothly as the 3/4 shifter shaft you will be done with that. So if more effort needs to be applied to that, try attaching the top cover to the transmission such that you can bolt one top cover bolt to the top of the transmission and the cover and shifting forks are in mid air (not in the transmission). The purpose is to use the transmission to hold the top cover so you can shift the shifter between 1st and 2nd gears and get that freed up.
The other half of the story is what you just posted. You should be able to move the clusters with your hands, they need to be able to glide over the main shaft easily. If not, it's tap, tap, tap, spray, spray, repeat until they do move. Try not to hammer the edges of the grears and wear some eye protection. I used a piece of wood and hammered on it.
This should fill in your weekend. Good luck. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | If the transmission is in neutral, and you can spin the output shaft, you might try that, and then try moving back into first gear. Sometimes these transmissions won't go into gear if eveything inside isn't lined up just right. A little movement of the output shaft could make all the difference in the world. | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | Just got back in from the garage, and the transmission shifts into all gears great! sfsutton, you were right. The rear cluster didn't want to move on the shaft, light persuasion with a rubber mallet and pb blaster and it moves free. Now for the test drive  . | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Good luck! The SM-420 in my 50 3600 was "stuck" in neutral when I got it. It took a lot of WD40 and persistence to get the shift rods to move freely. Now it works great.
Professional Novice
