4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
' Offline
Can somebody please tell me where the bottom hook on the throttle return spring goes on a 216? Without noting its original location, I disconnected it. It was easy to find where the spring hooks onto the throttle linkage, but that bottom connection is an illusive one.
Thanx in advance for your help.
A great lady, a stovebolt, & a small town! What else is there?
Aspiring '54 6400 dump truck owner
'Bolt On
The hole for the spring is in the oil pan flange of the block casting. Its probably obfuscated by grime.
Paint & Body Shop moderator
There should be a small triangular shaped sheet metal tab with a small hole on one of the oil pan bolts about right beneath the throttle bell crank. If it's missing it was probably just hooked over the edge of the oil pan.
Mine is hooked to the drian cock for the water jacket.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Drain Cock?? Way too far back, would be pulling back not down.
Some have a small tin tab on oil pan, others I've had a small hole in actual block edge for oil pan. Suppose hooking over oil pan tin edge may work, I wouldn't feel "safe" that way. W/out the spring the throttle WILL flop wide open, BTDT!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
My 54 has the hole in the edge of the block at the oil pan flange. If yours doesn't have one it would be easy to remove the closest oil pan bolt and put on a little tab.
54 3100 with 235
62 flatbed dump C60 with 261
' Offline
Thanx all!!
G.L. -- yes, the throttle does end up wide open, reaching down--in traffic--to pull the gas pedal back up would be an ugly thing!
I removed the oil pan to replace the gasket and must have lost that little tab. Sounds like the easiest and best thing will be to remove a pan bolt and put on a new tab--thanx Tony.
Thanx again for all the responses, I appreciate them.
Only 30 shopping days 'till Valentine's Day...
'Bolt On
216's have holes, 235's have the tab.
My 235 has the hole.
54 3100 with 235
