1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | '61 Apache 235. Can't figure out how the hand throttle cable mounts on the firewall from inside the cab. Here's a view from the engine compartment . | | | | | Joined: Aug 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 37 | I believe there should be a clip washer that snaps on the cable on the interior cab.It looks simular to a star style lock washer.Hope this helps | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I used a throttle cable hold down bracket from a Rochester carb, and screwed it to the firewall. Not original, but it works! | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 |
| | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | If you want I can take a pic of my '61 for you ? Let me know and can email it to you? RAK | | |
