3 members (Otto Skorzeny, klhansen, Bwana-Jim), 75 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#624424 02/28/2010 4:24 PM
1 Offline
I have a 37 puckup and want to build a fun inexpesive fenderless driver.I have thought about gong with a S10 frame or rebuilding the stock. Has anyone done an S10? If so any pictures or other advice or options?
Dale
94 vulture,i am rodding a 38 using the origional chassis,if i were you i would keep the origional chassis,try www.chassisengineering.com my buildup is at(www.hotrod.ie).herriot
C MON LETS GO
herriot #624480 02/28/2010 6:55 PM
Fenderless rods with OEM IFS usually don't look very good. Those are code words for ugly.
A fenderless rod should either have a straight axle which looks traditional, or an IFS that looks like it came off a championship or F-1 race car.
These of course are just my opinions, but my advice would be that you drop the S-10 idea and either rebuild the stock or look at much more sophisticated IFS possibilities.
OldSub #624511 02/28/2010 8:02 PM
I would personally go with the dropped axle
If you don't have your original frame and you already have a S-10 frame. You could lose the IFS, weld in a cross member or a suicide perch and run a transverse leaf, I-beam with hair pins or something. The sky and talent constraints are the limit. Have fun most of all.
KC in NH #624646 03/01/2010 1:42 AM
for that much work, just build a complete chassis.
