1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#623982 02/27/2010 1:38 AM
Ive got a 51 Chevy 3100 and when i put my weight on the frame (160 lbs) there is quite a pronounced creaking sound. I think its in the leaf springs and/or the shackles.
I can live with the sound, but id rather it not be there. Is there anything i can grease, oil, lube, tighten or loosen to lessen this sound?
Thanks.
'51 Chevrolet 3100 216 5-Window
chevnky #624242 02/28/2010 1:00 AM
Have you grease all 23 of the grease fittings and did they all take grease??? Also, the cab is supported by rubber grommets and that could be giving you squeak. RuGlyde is a good rubber lubricant for the rubber bushings. Also the leaf springs could be creating some noise. If you're ambitious, Delrin spring liners can be installed or using Damping Grease between the leaves can help with that.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Denny, I know where 16 of the grease fittings are (the 2 on each of the 8 shackles). Where are the other 7 fittings?
Also, where the rubber grommets supporting the cab?
Great idea on the leaf springs.
