| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | put a 235 in my '50, got it running and decided to change a wobbly harmonic balancer, ever since, everytime i start it i got a loud screeching noise from the starter. tried three different starters.also converted to 12 volt alternator system. anybody have any ideas as to what is causing this?
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It could be the drive mechanism is hanging up. Maybe a weak return spring. I'd pull the starter and bench check it or take it to your local shop and have them check it for you.
Drew
| | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I wonder why changing the balancer affected the starter...? If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
