| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 61 New Guy | | New Guy Joined: Jan 2010 Posts: 61 | Ive got a 51 Chevy 3100 and when i put my weight on the frame (160 lbs) there is quite a pronounced creaking sound. I think its in the leaf springs and/or the shackles.
I can live with the sound, but id rather it not be there. Is there anything i can grease, oil, lube, tighten or loosen to lessen this sound?
Thanks.
'51 Chevrolet 3100 216 5-Window
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Have you grease all 23 of the grease fittings and did they all take grease??? Also, the cab is supported by rubber grommets and that could be giving you squeak. RuGlyde is a good rubber lubricant for the rubber bushings. Also the leaf springs could be creating some noise. If you're ambitious, Delrin spring liners can be installed or using Damping Grease between the leaves can help with that. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 61 New Guy | | New Guy Joined: Jan 2010 Posts: 61 | Thanks Denny, I know where 16 of the grease fittings are (the 2 on each of the 8 shackles). Where are the other 7 fittings?
Also, where the rubber grommets supporting the cab?
Great idea on the leaf springs.
