5 members (FishinToms53, klhansen, Hanks custodian, 5 Window 9434, Mike Roache), 64 guests, and 0 robots.
Topics128,049
Posts1,055,634
My 65 C10 is difficult to shift through neutral from first to second and was wondering if its lack of lubrication in the column? Truck sat for 22 years before I got it.
1955 Chevy 3100
3B Offline
Hy hb32, try spraying some penetrating oil in at the bottom of the column [in the engine compartment] and up the column a bit where the shift levers come out. If you can get someone to shift the linkage as you're applying the penetrating oil it would have a better chance of working its way in, hope that helps.
jdl Offline
Common problem on all of the column shift. Could be lack of lubrication or worn out parts.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Y
Y Offline
it is one/all of the above stated conditions lack of lubrication, worn components, or improper adjustment. On my 49 you have to adjust the handle alignment or else it can bind up.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Did as suggested 3B and a little better but still a struggle getting through neutral. Any other thoughts?
1955 Chevy 3100
3B Offline
Hy hb32, does the shift linkage not want to "drop" down into the 2nd 3rd shift part of the pattern, do you have to push it out of 1st reverse part of the pattern, or do you have to fish around to find the 2nd 3rd gate. I would start by adjusting everything to make sure everything is lined up as it should be, hope that helps.
Nope just seems to be going through neutral. Going to disconnect the transmission rods and see what happens.
1955 Chevy 3100
