4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Why does the 61 steer and turn so easy compared to my 58?Is it the larger tires or a design upgrade.They are both half-ton ? The 61 feels like it is power assisted but it's not? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | radials vs your bias tires? made exactly that difference on mine
maybe your 58 has steering geometry problems? seized joints or lacking lube?
Bill | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Totally different set ups for the front ends. The 58 has straight axle, while the 61 may have the torsion bar suspension. I had both year models, and the torsion bar suspension was much easier to steer, especially at low speeds. Not really sure why, but the 58 was/is properly greased, the gear box is good, but when on the ground it can be a bit of a bear to turn the steering wheel. Especially if the truck is stopped. Seems like when I put radials on it the wheel was even harder to turn. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The balljoints in the suspension make a big difference, too. Less effort needed over kingpins. I'll have to check the specs to be sure, but there may also be a difference in the ratio of the steering boxes.
Bill Burmeister | | |
